I got dinged pretty hard this season and need to fix a bent stern rail. Does anyone have a scaled plan view drawing of the stern rail so that I can return the mounts to their proper locations? Or, does anyone have the dimensions and angles between the mounting brackets?
Making a template of my deck or measuring distances and angles won't be accurate because I have combings and other fittings that are in the way.
Any other advice for fixing this?
Eric
