#9277 04/10/10 11:03 AM
After 30 years, Love & War's original Gray hatches need replacement. Prior postings indicate the Lewmar size 60, without a flange, works for the forward hatch with its 19 7/8" square opening. Is there a Bomar that will also work there? I did not see any mention of a suitable replacement for the two smaller hatches with the 9 9/16" sq. openings. I would like to avoid deck surgery to make new hatches fit. Suggestions?
Steve Cole
Seal Beach, CA
Bomar makes hatches that will drop right in the smallest plastic Bomar show's a larger size due to the internal trim ring which you just thow away I've replaced both of mine on Falcon it a 30 minute job Just remember to use a lot of silcone and don't over tighten the screws
As I recall Hamilton marine had the best prices
Charlie Stoddard
Falcon #229
