1,203,266 Dacron Main
233,940 Ananda's Refit
Putting on a 3 blade 14 inch max prop on my 3/4 inch shaft, for my Yanmar 2GM20F, onboard LimeLight. The manufacture reccomended a setting of 20 degrees blade angle. Want to verify that 20 degrees isn't too much.
Marty
LimeLight
Hull 51
Marty - not too many people with J/30s have experience with the max-prop, as the two bladed Martec folding prop is the class approved configuration for one design. Unless someone else answers having experience with a max-prop on the J/30, I'd use what the manufacturer recommends.
The correct pitch and diameter of a prop is that which allows it to reach redline but not exceed it. This varies with prop configuration, condition of the bottom,and load in boat. Fully loaded for 3 weeks cruising will cost 200 to 300 RPM. Don't run against the throttle stop but run just below max RPM.
