Posts: 137 |
With this the tail end of the core repairs / another J30 has completed the task Has anyone replaced the exhaust thru hull with a stainless steel model? I have been on the hunt for one and may decide to have one made instead. Any heads up would be appreciated Taras BreakAway #532 ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/689/filename/18-nov2010-stern2.jpg)
Taras - nice work. Did you use gelcoat or Awlgrip? I bought fiberglass tube from Jamestown Distributors for the exhaust when I redid the transom on Rhapsody.
As the exhaust is water cooled and rubber hosed, perhaps a custom SS flange may be a bit of overkill?
Bill's idea of a fiberglass pipe will probably really bond well. On 526 we used the existing one as the inside skin was sound. and Horatio just worked from the inside skin out.
Posts: 137 |
It was finished with new gelcoat
Posts: 203 |
I see you did not cut all the way to the seams. Were you able to remove the core there or was it solid glass in the corners
