#10662 11/27/10 05:38 PM
With this the tail end of the core repairs / another J30 has completed the task
Has anyone replaced the exhaust thru hull with a stainless steel model? I have been on the hunt for one and may decide to have one made instead.
Any heads up would be appreciated
Taras
BreakAway
#532
Taras #10673 11/28/10 01:13 PM
Taras - nice work. Did you use gelcoat or Awlgrip? I bought fiberglass tube from Jamestown Distributors for the exhaust when I redid the transom on Rhapsody.
As the exhaust is water cooled and rubber hosed, perhaps a custom SS flange may be a bit of overkill?
Bill's idea of a fiberglass pipe will probably really bond well. On 526 we used the existing one as the inside skin was sound. and Horatio just worked from the inside skin out.
Taras #10694 11/30/10 09:34 PM
It was finished with new gelcoat
Taras #10702 12/03/10 06:19 PM
I see you did not cut all the way to the seams. Were you able to remove the core there or was it solid glass in the corners
