2gm losing prime
346,809
253,357
233,910
173,727
2gm losing prime
12289
08/30/11
04:00 PM
Dec 2009
Jacksonville, Fl
bananas
bananas
Dec 2009
Jacksonville, Fl
anyone had a problem with the engine fuel filter leaking and the engine losing prime when shut down.
Re: 2gm losing prime
bananas
12290
08/30/11
04:03 PM
Rhapsody #348
Rhapsody #348
make sure that the copper washers on the fuel lines are good. They are cheap and better replaced than reused.
Bill Kneller
Past Owner - Rhapsody J/30 #348
Projects & Documentation
Vento Solare J/109 #266
bananas
12291
08/30/11
04:44 PM
Jun 2001
Hammond La.
kbuhler
Gulf Coast District Governor
kbuhler
Jun 2001
Hammond La.
Yes, I have this past summer. The bleed screw was the problem. About 50 bucks took care of it. After 30+ years it just were out. I replaced the bowl and the washers Jalapeno30
08/30/11
04:48 PM
bananas
12292
08/30/11
05:30 PM
Nov 2010
Vancouver, BC, Canada
Vampire
Vampire
Nov 2010
Did you service the filter?
Many times the o ring on the filter housing can get pinched or people over tighten the threaded ring and crack it.
Each of these allow an air bleed.
Vampire #18 Don
Bite Me
