#12289 08/30/11 05:00 PM
anyone had a problem with the engine fuel filter leaking and the engine losing prime when shut down.
bananas #12290 08/30/11 05:03 PM
make sure that the copper washers on the fuel lines are good. They are cheap and better replaced than reused.
bananas #12291 08/30/11 05:44 PM
Gulf Coast District Governor
Yes, I have this past summer. The bleed screw was the problem. About 50 bucks took care of it. After 30+ years it just were out. I replaced the bowl and the washers Jalapeno30
bananas #12292 08/30/11 06:30 PM
Did you service the filter?
Many times the o ring on the filter housing can get pinched or people over tighten the threaded ring and crack it.
Each of these allow an air bleed.
Vampire #18 Don
Bite Me
