#15253 10/16/13 02:47 PM
I am not a mechanic, but I followed Rhapsody's step by step instructions on oil/filter change with the Pella Extractor.
Worked great, but it took forever to suck the oil out of the sump.
I assumed it would heat up right away when I ran the engine for about 5 minutes.
It must take loner??? It was about 50 degrees out. What is a reasonable amount of time to run the engine to warm up the oil to make the extraction faster next time?
Chris
Chris_Kirstin #15254 10/16/13 03:13 PM
Running the engine does not necessarily heat the engine up. It needs to be put under load. If you doubled up the dock lines and ran the engine for a couple of minutes turning the prop at 1500 rpm, that would be sufficient. At 50 degrees the oil is fairly "thick".
I actually cool down the engine by running it with no load 1200 RPM for about 5 minutes.
Rhapsody #348 #15255 10/16/13 03:18 PM
Thanks - Next year.
