1,179,634 Dacron Main
225,988 Ananda's Refit
#15491 02/25/14 08:26 PM
J
J Offline
Could someone identify these spreaders? Is this the Hall Spars fix? Some other modification?
There doesn't seem to be a bracket, though clearly the spreaders are bolted to some sort of internal structure (see shadow under tape). I'm hoping it's a through-bar retrofit that eliminates the stock spreader/mast failure issue.
EDIT: Still working on photo... standby
[Linked Image from i1319.photobucket.com]
EDIT 2: Got it.
J
J Offline
And as an added bonus, while discussing masts...
What do you suppose the bail on the front of the mast base is used for? I haven't noticed other J/30s with this:
Looks exactly like my Hall Spar spreaders. The tape is covering a pair of clevis & cotter pins which pass through the internal bar. It is designed for a tight fit, which holds it tight - so much so that it's a good idea to have a wood screw clamp to squeeze the mast a bit when putting it all together.
The bail looks like a convenient place to clip your spare halyards to when racing or doing a sail change. It doesn't look strong enough to run a foreguy to for the spin pole.
Per Chris's reply, it appears you have the spreader bar fix installed.
I thinking it is a foreguy anchor point. Just high enough to allow the hatch to be open for a spin hoist or drop without interfering with the guy.
The new J/22s at Sail Newport last summer all blew out the vang attachment to the boom and replaced it with a similar unit ... they are stronger than they appear.
[[ Bill ... will have to get you out on a J/22 now that you have time on your hands this summer. ]]
0 members (), 279 guests, and 23 robots.
