1,202,649 Dacron Main
233,637 Ananda's Refit
#16434 08/15/15 07:17 AM
so I've been cleaning out the J30 locker following blocks etc are for sale
blocks cars etc.
Harken small boat block w/ bail 166 qty 5 $50.00 set
Schaeffer spring load block w/ car stainless 705-9 qty $200.00 set
Merriam double sheet car w/ track qty 2 $200.00 set
Harken small boat triple block w/ bail 86 qty 2 $25.00 each
Harken small boat triple block w/ bail and jammer qty 1 $40.00 each
Harken mid range double w/ becket 1545 qty 1 $100.00 each
Harken small check block 27 qty 2 $15.00 set
2" head stay toggle qty 1 $15.00 each
Harken small check blocks used set of 2 1 $10.00 each
loos regular style Loos gauge 1 $40.00 each
loos Pro style Lous gauge 1 $60.00 each
Deck organizer triple 1 $25.00 each
email cssj30@gmail.com
Charlie Stoddard
Falcon #229
Charlie,
I'll take your two impellers if you still have them.
Also, I am looking for new style halyard stoppers to replace the original old style. If you have those, I will buy them too.
To save shipping, I will be in Marion for the N/A's
Thanks
Russ
W Offline
Charlie ,
will take 2 rudder pins and the triple deck organizer
Willie
Russ
Got it will set the jammers and impellers aside for you
cssj30@gmail.com
Charlie Stoddard
Falcon #229
Willie pins and deck organizer is yours
cssj30@gmail.com
Charlie Stoddard
Falcon #229
Do you have any photos of the two remaining pins? I have a clunky rudder so I am wondering if they are worn less than my pins.
