Posts: 186 |
so I've been cleaning out the J30 locker following blocks etc are for sale blocks cars etc. Harken small boat block w/ bail 166 qty 5 $50.00 set Schaeffer spring load block w/ car stainless 705-9 qty $200.00 set Merriam double sheet car w/ track qty 2 $200.00 set Harken small boat triple block w/ bail 86 qty 2 $25.00 each Harken small boat triple block w/ bail and jammer qty 1 $40.00 each Harken mid range double w/ becket 1545 qty 1 $100.00 each Harken small check block 27 qty 2 $15.00 set 2" head stay toggle qty 1 $15.00 each Harken small check blocks used set of 2 1 $10.00 each loos regular style Loos gauge 1 $40.00 each loos Pro style Lous gauge 1 $60.00 each Deck organizer triple 1 $25.00 each
email cssj30@gmail.com
Charlie Stoddard Falcon #229
Posts: 393 |
Charlie, I'll take your two impellers if you still have them. Also, I am looking for new style halyard stoppers to replace the original old style. If you have those, I will buy them too. To save shipping, I will be in Marion for the N/A's Thanks Russ
Posts: 14 |
Charlie , will take 2 rudder pins and the triple deck organizer Willie
Posts: 186 |
Russ
Got it will set the jammers and impellers aside for you
cssj30@gmail.com
Posts: 186 |
Willie pins and deck organizer is yours
cssj30@gmail.com
Posts: 381 |
Do you have any photos of the two remaining pins? I have a clunky rudder so I am wondering if they are worn less than my pins.
