Posts: 74 |
Bil, I still have the original Origo pressure alcohol stove. I'll pull it out and test it. As I said above if you'll send me an email I'll send you photos. I'm at: ravenracingdoug@gmail.com Are you after lifelines or the cabintop grabrails? I made up heavier teak cabintop rails...they should clean up fine. Doug.
Doug Marshall Koeshtkah #207
Posts: 14 |
Hi Doug, Apologies for finally getting back to you - we’ve been gearing up to head out to sea for work, which turns out to be tricky in the middle of a pandemic. I’m still interested in the head sink, and am also interested in the prop and shaft assembly if it’s straight and in good shape, might be interested in your injectors too if they’re in good shape. Our final port call is in Newport, OR near the beginning of September- I could swing by on the way back up to WA to pick the things up? Let me know what you think!
Mouse #359
Posts: 74 |
Hi Kellen, Sounds great! I have the entire drive train so I can pull the shaft, prop and coupler and check the shaft on some v-blocks for straightness. There was no perceptible vibration on it prior to pulling (other than the usual Yanmar stuff), but I should make sure it didn't get a strap around it during the lift at Schooner Creek. Will you be in reach during your sea duty? That'll give me time to pull the sink and everything, too.
Posts: 14 |
Hi Doug, I'll have email (rosburk AT my DOT uri DOT edu). Shoot me an email and we can get the conversion rolling about the financial aspect too. Thanks!
Mouse #359
Posts: 42 |
Hi there Doug, tell us about your sails!
Posts: 20 |
Doug I have rags for sails myself. Gary
Posts: 58 |
Hi Doug, Can I buy your handle off your Y-Valve?
Posts: 74 |
Hi Pabs, Mine didn't have one...just plumbed to the holding tank.
Posts: 74 |
Got the Mylar job out for measurements and it's: Luff (tack fitting to halyard eye): 33'-11.75" Luff (PHRF: Tack to intersection of leach and luff): 34'-5" Leach: 31'-11.75" Foot: 19'-1" Foot round: 15" LP" 18'-0" Banks 2008 raised four times. Stored rolled. Asking $1100 ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2579/filename/IMG_6048.JPG) ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2580/filename/IMG_6049.JPG) ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2581/filename/IMG_6050.JPG) ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2582/filename/IMG_6051.JPG) ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/2583/filename/IMG_6053.JPG)
Posts: 21 |
Do you still have the set of cushions?
