1,146,084 Dacron Main
212,985 Ananda's Refit
Page 2 of 4 1 2 3 4
Bil,
I still have the original Origo pressure alcohol stove. I'll pull it out and test it. As I said above if you'll send me an email I'll send you photos. I'm at: ravenracingdoug@gmail.com Are you after lifelines or the cabintop grabrails? I made up heavier teak cabintop rails...they should clean up fine.
Doug.
Doug Marshall
Koeshtkah #207
K
K Offline
Hi Doug,
Apologies for finally getting back to you - we’ve been gearing up to head out to sea for work, which turns out to be tricky in the middle of a pandemic. I’m still interested in the head sink, and am also interested in the prop and shaft assembly if it’s straight and in good shape, might be interested in your injectors too if they’re in good shape. Our final port call is in Newport, OR near the beginning of September- I could swing by on the way back up to WA to pick the things up? Let me know what you think!
Mouse #359
Hi Kellen,
Sounds great! I have the entire drive train so I can pull the shaft, prop and coupler and check the shaft on some v-blocks for straightness. There was no perceptible vibration on it prior to pulling (other than the usual Yanmar stuff), but I should make sure it didn't get a strap around it during the lift at Schooner Creek. Will you be in reach during your sea duty? That'll give me time to pull the sink and everything, too.
Doug Marshall
Koeshtkah #207
K
K Offline
Hi Doug, I'll have email (rosburk AT my DOT uri DOT edu). Shoot me an email and we can get the conversion rolling about the financial aspect too. Thanks!
Mouse #359
Hi there Doug, tell us about your sails!
G
G Offline
Doug I have rags for sails myself.
Gary
P
P Offline
Hi Doug, Can I buy your handle off your Y-Valve?
Hi Pabs,
Mine didn't have one...just plumbed to the holding tank.
Doug Marshall
Koeshtkah #207
Got the Mylar job out for measurements and it's:
Luff (tack fitting to halyard eye): 33'-11.75"
Luff (PHRF: Tack to intersection of leach and luff): 34'-5"
Leach: 31'-11.75"
Foot: 19'-1"
Foot round: 15"
LP" 18'-0"
Banks 2008 raised four times. Stored rolled. Asking $1100
Doug Marshall
Koeshtkah #207
C Offline
Do you still have the set of cushions?
Page 2 of 4 1 2 3 4
0 members (), 167 guests, and 4 robots.
