1,145,990 Dacron Main
212,777 Ananda's Refit
#1875 03/14/08 09:28 PM
I'm leaving the mast stepped, and I want to work on the chain plates.
Can I still safely motor around with just the forestay and rearstay tight?
I won't have the boom or headsail weight on the mast.
mangomadnessj30.blogspot.com
Former Owner, Mango Madness
#1876 03/14/08 10:10 PM
Assuming there are no heavy seas, I would say yes. I know when a crane is used to unstep the mast on Rhapsody, it seems like it requires a lot of pressure to pull it the 1st 1/2" off the mounting flange. The headstay and backstay should hold the pole in the hole!
#1877 03/19/08 06:54 PM
for a added security I would run a jib halyard to the stanchion base on either side and tension them .
#1878 03/19/08 07:22 PM
Yea, I was going to do that but, I'm removing everything from the topsides except the shifter, and the toe rails.
#1879 03/19/08 07:22 PM
and the chocks and bow/stern cleats.
#1880 03/28/08 01:03 PM
You could also tap some wedges in from below and from the top that would probably stop the mast from coming out.
