Posts: 156 |
I'm leaving the mast stepped, and I want to work on the chain plates.
Can I still safely motor around with just the forestay and rearstay tight?
I won't have the boom or headsail weight on the mast.
Assuming there are no heavy seas, I would say yes. I know when a crane is used to unstep the mast on Rhapsody, it seems like it requires a lot of pressure to pull it the 1st 1/2" off the mounting flange. The headstay and backstay should hold the pole in the hole!
Posts: 21 |
for a added security I would run a jib halyard to the stanchion base on either side and tension them .
Posts: 156 |
Yea, I was going to do that but, I'm removing everything from the topsides except the shifter, and the toe rails.
Posts: 156 |
and the chocks and bow/stern cleats.
Posts: 649 |
You could also tap some wedges in from below and from the top that would probably stop the mast from coming out.
