E
E Offline
In pulling a through-hull that was suspected to be NOT potted and to pass through exposed core, it was found that the through-hull was indeed potted in glass and resin and was isolated from the core.
Did TPI seal or pot all the trhough-hulls when the boats were built? Other than the exhaust, do any pass directly through core? If so, which ones? Thanks for the help.
Eric,
On #397 there is solid glass which is how I assume it came from the factory.
David
On #337, I can confirm that the part of the hull where the transducers and toilet water intake through-hull are mounted is solid glass, presumably from the factory. I can see the inside of the hull get thinner around that whole area due to the lack of core.
I haven't examined the cooling water intake or overboard waste discharge, so I don't know about these.
Ryan Pierce, #337
Can anyone confirm the core issue around the through hulls? Which ones pass through plain core?
mangomadnessj30.blogspot.com
Former Owner, Mango Madness
known stuff I've found to be not isolated from core (above & below waterline):
Engine Exhaust
Around Chain Plates
hinges on cockpit and anchor lockers
all hardware on cabin top
stanchion base mounting holes
Confirmed isolated:
Speed & Depth Xdcr
Head Seawater Flushing
I can confirm the the engine intake and galley sink drain is isolated from the core. I assume the head sink is as well but have not verified.
John
Engine Exhaust
Around Chain Plates
Confirmed isolated:
Speed & Depth Xdcr
