Page 1 of 3 1 2 3
#3795 11/13/07 09:07 AM
Anyone had any experience rebuilding their J/30 rudder?
I wouldn't mind knowing the anatomy of the rudder before I start ripping it apart.
Thanks
Jason Penney
#3796 11/13/07 10:25 AM
John McArthur (Smiles) had a new rudder fabricated and brought it to the Annapolis NAs for the Board of Governors to inspect. Physically, it looks identical to the stock J/30 Class rudder since it was built from templates. It is lighter though. There is an action for a Naval Architect to analyze the impact of rudder weight and determine if there should be a specification before approving the replacement rudder as an alternate source to one fabricated by TPI. Hope this helps!
#3797 02/02/08 04:21 PM
I've decided to rebuild the rudder today.
I've posted my progress on the sailrattleandhum.blogspot.com.
Jason Penney
Rattle and Hum, #124
#3798 02/03/08 09:53 AM
John McArthur (Smiles) copied me on an email to Jason with pictures of the broken rudder, allowing the core and construction to be seen. I've posted the information with pictures below for all to see.
Jason,
Here's some pictures of a "Failed" J30 rudder from IdaSailor. IdaSailor made as rudder for me last year. Most of the J30 rudders I have checked out are in the 70 to 80 pound range "Wet". IdaSailor's rudder I purchase was 40#.
Bill, I talked with Joel at Ida Sailor and he thinks it would be easy to make the new rudder weigh around 55-65#.
John McArthur
Hi John,
sorry for the delay, had to dig the rudder pieces out from under a pile of other broken blades.
Weight for both pieces is 53 lbs.
Thanks for business and your patience. I look forward to hearing the results of your class measurer and your experience with the rudder under sail.
fair winds,
-Joel
Joel Santarone
General Manager
IdaSailor Marine Inc. www.idasailor.com
866-400-2204 toll free
208-375-2204 shop
sailboats@idasailor.com
[Linked Image from j30.us]
[Linked Image from j30.us] [Linked Image from j30.us]
[This message has been edited by Rhapsody #348 (edited 02-03-2008).]
#3799 02/03/08 06:16 PM
Jason,
I just looked at the pictures on the blog from 2 Feb. I assume the next steps are to chisel out the old balsa, then cut new core in the shape of the section that was taken out. Is your plan to lay in new core with the "V" grooves up against the contour of the glass remaining in the rudder, then grind to match the contour on the open side? How many core pieces (e.g. what approx size) do you think will make up the new core? Nice documentation you've got on your blog. Keep up the good work & Good Luck!
Bill
#3800 02/04/08 04:55 PM
I cleaned the balsa and ground down the rough edges on the glass...so I'm ready to start rebuilding.
A couple notes worth mentioning after looking at the broken rudder:
1) The rudder has a foam core (i think) that is shaped, then has balsa wood wrapped around this "shape". The balsa wood is uniformally 2 sizes:
a) 1/4 inch balsa between 3.25 and 5.25 inches from the trailing edge (it's not shaped and is uniformally the same thickness).
b) 1/2 inch balsa 5.25 inches from the trailing edge to the leading edge (it as well is not shaped and is uniformally the same thickness).
2) The balsa wood was so rotten that using the claw on a hammer I could just pull the balsa off...no chissel was required this time.
#3801 02/04/08 05:00 PM
Oh...and another note...my rudder weighed 85 pounds before I split it....and my garbage can is REALLY heavy with rotten balsa....it will be interesting to see what it will weigh when I'm done. Other than layering solid glass where the hardware attaches I don't plan on doing anything special.
Jason Penney
#3802 02/12/08 10:03 AM
OK I need a favour (Canadian spelling);
Someone out there must have the rudder and keel templates drawn to scale in CAD or something. If so could I get a copy Emailed to me?
Thanks
Jason Penney
#3803 02/12/08 12:02 PM
I found this doing a search in our database;
I have the keel templates avaiable on my cad package at work. e-mail a note with a u.p.s. shipping address and I will be glad to plot off a full size set that can be transfered to foam or wood.
Harley
HNETHKEN@prodigy.net"
The fleet directory shows Harley Nethken;
222 Land Shark 30085 Harley Nethken harley@tech-con.net .
You might shoot him an email.
AC s/v Rauzer II #448
[This message has been edited by alcal1750 (edited 02-12-2008).]
AC
#3804 02/21/08 08:44 AM
Harley Emailed me with the CAD drawings to scale.
Thanks Harley
Page 1 of 3 1 2 3
