October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,197,865 Dacron Main
232,285 Ananda's Refit
Members1,065
#4070 02/09/05 01:05 PM
J
J Offline
I am considering adding a roller furling unit. The CDI uses a #6 luff . Does anyone know what size luff tape is on our class sails?
#4071 02/09/05 09:33 PM
pretty sure its 6
thats at least whats my old tuff luff is supposed to be...
I am converting to roller furler as we speak and the harken unit i got is 6 as well
Thor
Thor
#4072 02/11/05 09:41 AM
So, having just carried a new tuff luff to the islands... this makes me wonder... I saw in the classified someone found they needed a 1206 extrusion, not a 1205.... I had a 1205, replaced it with a 1205, then tried to use some "new" sails.....they would not go up the forestay....not a good thing during racing season. To confuse matters, my old cruising #3 would also not come down. Whats up??? Most of my old sails ame with the boat, I never had a drama with my racing sails from North, then got some sails from Cheasapeke, and a new tuff luff.... didn't work. Perhaps I should figure this out before I put up the tuffluff and/or buy sails from any other class members
#4073 02/12/05 01:28 PM
Sails for J/30s can have either a #5 or a #6 luff as both types of Tuffluffs are used on various installations. So the #5 luff tapes can fit either unit, but have been known to pull out of a #6 extrusion. The #6 luff tapes are usually too tight to go up a #5 extrusion.
#4074 02/12/05 05:49 PM
dwl Offline
We replaced out headfoil this fall. (After 25 years of hard service, our original detonated in 25-30) We went through the whole drill. The tuffluff system permits either a 1205 or 1206 over the headstay. Not surprisingly, the 1205 accepts #5 tape and the 1206 #6 tape.
The headfoil-2 system uses the #6 sized foil
only for the J/30 headstay. In theory, #5 tape will work on both the #5 and #6 foils. In pratice, you may find #5 tape pulling free of a #6 foil. You won't get #6 tape up a #5 sized tuffluff.
- David
#4075 02/18/05 11:30 PM
J
J Offline
I am going with the profurl R-35 ( the racing version) I am hoping that if I place the drum close to the deck I wont have to alter all of my sails. Any advice?
thanks,
clint
#4076 02/19/05 08:35 PM
J
J Offline
thanks,
clint
#4077 02/19/05 08:41 PM
J
J Offline
You will likely need to modify your sails. Even if you keep furling unit low it will raise your attachment point off the deck (and the horns) 6 to 9" or more. In addition you need to allow room for swivel at top which effectively lowers your hoist height. #3s usually are short on hoist and might be usable. #1's and #2's are generally not. You might think about modifying only your #2 (since it may become an optional sail for one design purposes) and keeping your #1 and #3 for racing. They might work if you can remove drum and not use furler if racing. FYI, I had a new 145 made for the furler and as my primary cruising sail.
#4078 02/22/05 03:36 PM
I am replacing the head foil on my boat, and am wodering what the difference is between the Tuff Luff & Head Foil 2 systems. Head Foil 2 seems to be what the boat came with, and I can probably replace just the extrusion if I go with that system, vs. total replacement if I go to Tuff Luff.
#4079 02/22/05 04:18 PM
dwl Offline
I had the same choice this past fall. Just replacing the extrusion was cheaper, and pretty straightforward.
- David
