I have a 1979 J-30. I am going to install some new Raytheon instruments on it. The transducer for the depth guage is currently located next to the keel on the port side. I would like to install it in front of the keel but haven't found a suitable place - do any of you have your transducer mounted in front of the keel - if so where did you mount it? Also Do any of you have your instruments mounted above the companionway hatch? if so how did you mount and install them?
Posts: 24 |
My transducer for depth is mounted forward of keel. The access is under the star. side of v-berth.It is quite accessable here and works ok heeled to port or starboard. My instruments are mounted in bulkhead on either side of hatch.Manufacturers or marine supply stores may have brackets to mount above companionway.lots of boats have them there.
