October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
1,064 Registered Users
1,198,671 Dacron Main
232,487 Ananda's Refit
Members1,065
#4591 08/10/06 09:16 AM
T Offline
I noticed 1 of the 4 bolts in my outboard upper rudder plate (fastened to the transom)has come loose. The other 3 appear to be solid. Does anyone have an idea for a quick fix? Or, has anyone experienced this and think I might have a bigger problem waiting to happen? I am mildly concerned that the natural play with the rudder pins could loosen the other 3 tight bolts by the end of the season. With a dozen races left I'd prefer not to haul at this point. Any ideas would be welcome.
Ty #495
#4592 08/11/06 12:57 PM
Why not get down inside with a wrench & simply tighten all the bolts on both plates ?
While you are at it, put a dab of goo in the bolt holes for good measure, to seal out the juices.
Dell Todd
#311 Temptation
Holland MI
#4593 08/11/06 02:43 PM
T Offline
The others are already tight, the loose one comes directly out. I suppose I should pop the yanmar instrument panel out for a real look at what's behind there. A crumbling mess at the mooring is better than being rudderless halfway around the race course.
Thanks.
#4594 08/14/06 01:33 PM
Ty,
If you need a hand let me know.
David
#397
