My tack was intermitent last year, and non-functional this year. For those who have had the same problem, is it usually the cable, the instrument, or something else?
My usual issue is the contacts on the sending unit usually get fouled. I take a wire brush and some fine sandpaper and give them a little cleaning and that solves the issue.
David #397
Originally posted by dbows: My usual issue is the contacts on the sending unit usually get fouled. I take a wire brush and some fine sandpaper and give them a little cleaning and that solves the issue.
David #397
David:
thanks for the advice; it was spot on. Tach is not working like a charm.
