1,203,266 Dacron Main
233,940 Ananda's Refit
#7441 06/02/09 07:05 PM
What kind of truck do most people use to trailer there j-30's to regattas
Luke Buxton
Evelyn Hull #179
Although, it is not optimal it works for the 100 miles to the lake, I pull my J with 1996 dodge 1500 5.2 engine, doesn't like hills. I can travel comfortable at 60mph. The trailer is a sailor trailer, that I had modified to fit the J30. It is rated for 10,000lbs I think.
I have used an f-250 and f-350. Both fine, but the f-350 w/ a diesel is what i have now and is enough power. I have a 3 axle trailer, a little big but works fine.
John
Madcap
358
John
Madcap 358
Aeolus #085 is on a Triad trailer designed with extra pads, towed by a Dodge 3500 diesel. Hills,expressway, etc. don't even know its back there.
Luke,
I have an old 2000 F-350 diesel. Works great. If you thinking of towing Evelyn to the CPYC NAs give me a call.
John McArthur CELL 203-253-1686
Luke,
For Fuzzy Wuzzy we use a dual axle (Tor-flex) Triad with 8 supports and a Suburban with the 6 l engine, HD transmission, suspension and rear axle. Total max combined weight is 16,000# - just on the fence - towing is no problem hills or not - we get about 9 mpg.
For long distance towing I would go with a diesel truck.
Bengt Johansson
