Ok now lets look at #526 cutouts. if that is 3/4 balsa core with two fiberglass skins ... those cut outs would be at least 1 inch deep. But they don't look like 1 in. deep to me. roger, roger on the hull though. ![[Linked Image from captainvic.com]](http://captainvic.com/threequarter.jpg)
Posts: 148 |
Phantom is number 364, must be the difference in 500 series
Posts: 111 |
roger, roger on the hull though. #526 is pretty close to the end of the production of J30,s and they must have decided not to core that bulkhead. #448 has 3/4 inch balsa core in those bulkheads as I had to seal up some compass cut-outs that had exposed core when I bought the boat. (That is, the previous owner made larger cut-outs and slapped in the new compasses without sealing the newly exposed core.)
AC
Roger, roger ... will confrim on #505 later today. The bulkhead is cored but seems to be 3/8ths.
... As we stumble across differences between "later" and "earlier" editions.
And there were a few half and halfs as well with Fuzzy Wuzzy in the middle ... but wait ... perhaps that name reflects the "edition"?
Checked #505 this afternoon ... core on 500 series seems to be 1/4 in. for that cabin bulkhead ... which I think is also what they used for the straight sides of the cockpit.
Posts: 190 |
Thought I would post some pictures of these Beckson ports i was talking about. I think its a really good easy solution - as you can see, the clips for my new Tacktick stuff just screwed right on (repainting the interior, which was only half done in the pictures. -dan ![[Linked Image]](https://j30.us/ubbthreads/ubbthreads.php/ubb/download/Number/407/filename/100_3500.JPG)
