Posts: 679 |
We ripped this hatch right out of the deck tensioning a fouled jib halyard at the leeward mark during the NOOD. I figure it's one of these, anyone know which? (And yes I did search the forum.): Bomar/Gray/Pompanette 900 series Or should I go for a low profile Lewmar like we have on the bow?
Posts: 457 |
Go for the Lewmar-more durable.
Posts: 16 |
Bob,
I replaced the same size one over the head a year or two ago and found the only drop in replacement was the Bomar. The other manufacturers hatches would require some modifications to the cut out. Things may have changed. I found Fawcett's to be pretty helpful reviewing catalogs and reasonable on price with our discount.
Tom
tom watson
Posts: 649 |
I replaced with the lewmars and if you use the ones without flanges then it fits perfectly.
Posts: 679 |
Tom & Dave, either of you know the part number you used? Didn't get a chance to measure Wednesday night, what with the MOB drill and all. Since the original lasted 27 years, think it's worth paying more for the more durable Lewmar?
Posts: 649 |
http://www.defender.com/product.jsp?path=-1|6880|6881|320591|368559&id=7052
Ocean Size 10 Flat (No Flang)
Posts: 186 |
I've used the Bomar ones Hamliton Marine has the best pricing
Charlie Stoddard Falcon #229
Posts: 162 |
I've broken the handle on the hatch in the head. Might any of you with busted hatches have saved a handle that I might be able to buy off you?
depending on how you use the boat ... in my case racing and day sailing with very marginal use of the head ... I drilled a hole though the hatch and bolted it down. 5 min job. That handle no break no mor.
Posts: 162 |
Good idea but I would rather the hatch function as we cruise the boat in the summer as well.
